powerman3007
- Jul 13, 2011
- 4
I am installing a new flywheel cover and primary shaft ball bearing and seals on my Volvo Penta 430B with a SP-C outdrive. The flywheel cover came bundled with a ball bearing; part #3851019, but the parts breakdown shows that it uses the ball bearing part #11013. Here is a link to the breakdown:
http://www.volvopentastore.com/Flywheel-Cover-Primary-Shaft-And-Clamp-Ring-Kit-Drive-Sp-C-Dp-C/dm/*******.226412204--**********.590565821--store_id.366--view_id.767443
Does anyone know which is the correct bearing to use?
