Usage: 212 hours Made 200 hours Service on July 1, 2011
Saturday 10 September entered water to the compartment engine, giving origin to an electrical problem, preventing the engine to start. This gave origin to change several elements of the electrical system, such as the ICM module. Cap Distributor, Rotor, Coil, etc. They ordered and reviewed cables, plugs, etc., this part of the electrical system being revised.
By the side of the system of gasoline, a flushing of the pond was taking all the water which had accumulated, changed the water/fuel filter cleanse the carburetor changed the carburetor filter, in synthesis the entire fuel system was revised.
Result: The engine starts without a problem and works even in idle, including being arrested the boat can accelerate up to 3000 3500 RPM. Then being launched to idle speed, the engine still running smooth, but when accelerate up to 1500 / 2000 RPM the engine does not respond and working very uneven, as if you were running only on 6 / 7-cylinder, if you can pass over the 2000 RPM without that stops the engine, then it normalizes the functioning and you can upload to 3000 / 3500 RPM without problem. Even at the critical point of malfunction was tested to put gasoline directly into the carburetor, without any positive results, therefore this is ruled out that the problem is the fuel line, therefore the characteristics of the problem I think that it should the electrical system, there is possibly a cable changed position. ???
