Re: Is it bad if Gearcase oil is not changed before winter?
or can I just change it when winter is over?
since yer gonna change it when winter is over, why not do it now? changed is changed, be it now or later. + if ya do it now you'll know the answers to Don S' comment as to knowing there's no water in the gear lub.
look at it this way too. ya changed yer engine oil didn't ya for winter layup. nice, clean, fresh engine oil for the lay up. might as well treat the drive the same way.
The only reason I wouldn't be able to change it now is because it is put away in a barn for the winter and there is no way to start it. I read where it says the engine should be warm when changing it.
ya don't need to start it to drain it (the drive). the gear lub will take longer to drain since it's cold lub. but it'll eventually drain out. having the engine warm has nothing to do with the drive. running the engine to warm it up also turns all drive components except the prop shaft assuming your in neu. this warms up the drive lub so it is more viscus and drains faster...
