jspringator
- May 27, 2006
- 415
I just had a new fuel pump put on. When winterizing today, I noticed a steady drip of fuel from where the metal fuel line attaches to the base of the carb. Looks like a brass compression nut holding on the line.
Is this something a simple tightening of the compression nut will cure, or should I plan on something else? Is there a O ring in there that goes bad?
Don't suggest I take it back. What a nightmare. I broke down on the other end of the lake and had to use a different shop.
