honda460ex
- May 12, 2011
- 69
I know I will make a few cringe with this, but in my bass boat I only run two batteries. I have a 12/24v 56lb thrust trolling motor and my 115hp Mariner. I use battery 1 to start the motor and run all 12v accessories (as well as run my TM on 12v if I like which I never do). Battery 2 of course is wired 24v with a jumper from battery 1 strictly for the TM. I have ran my batteries for two days straight with no charge (except for the big motor charging on battery 1 when running from spot to spot) on Lake Cumberland and never had a problem firing the big motor back up, but on big trips I occasionally take a small jump pack just in case so I don't leave myself stranded. My boat is light for a fiberglass boat and only 17ft so it doesn't take a lot of thrust to move her. Getting to the point though, I have no onboard charger and have never wired one. Can a 2 bank 20amp charger that is capable of 12v or 24v wiring be wired for 24v in my boat without hindering my big motor wiring, accessories on battery 1, or the charger itself? OR, option 2, can I wire it one bank to each battery and be fine? I figured if I tried option 2 that I would have to disconnect my jumper every time I charge and possibly have to disconnect the charger from battery 2 every time I use the TM... True or False??? Also, I know my setup is not optimal by far. I don't really want to debate that. I know a third battery would be best but I don't want the added weight or space it would take. I just want to know what will and will not work. Thank you all. Any help is appreciated greatly.
