Hi all,
I am looking to change out the water pump in a 89 Evinrude 3 h.p. Am I going to have to remove the power head to get the lower foot off? I took the two bolts out holding it on but it only dropped like 1/8 of an inch. Is that because there is a gear arm running up there that is parallel to the shaft that needs a bolt removed to come out? The motor has forward and neutral, if that is relevant.
