Was wondering why it is necessary to run the coolant hoses through the manifold on a FWC engine? Any thoughts?
Hi and thanks for the welcome. I have Marine Power 350 blocks that are closed system with heat exchanger and raw water cooled. I guess my question is why does the closed system run into and out of the manifolds? Car motors do not use the coolant to run through manifolds.
So, the closed system goes through the manifold and cools the manifold down?
