Compression Readings.. V8 5.7 Need Input Please!!
jmw129
Hey Guys,
I need your opion on the following compression reading regarding the health of this engine that is for sale. Seller says it runs good, it's an older 1978 V8 5.7 Merc.
He told me he took the following reading when he ran the engine cold. Does it really make a difference with cold vs. wet compression reading?
1 - 155
2 -160
3 - 140
4 - 155
5 - 140
6 - 160
7 - 160
8 - 145
Is this engine healthy enough to drop into another boat?
Thx Team!
Oshkosh1
Ensign
Re: Compression Readings.. V8 5.7 Need Input Please!!
You need to take the compression when the engine is up to operating temp.
Cold comp numbers are not reliable.
Those numbers are a little far apart...10-12 lbs should be the most difference between any two IMO. 15 is borderline, 20 is time to price a rebuild.
However...as I stated, a cold compression test does not give a true picture of it's health at operating temps.
Also...do they change with a little oil squirted in?...Was the throttle blocked open? It's not JUST the high number...too many variables...not enough info.
dollarten
Hey Guys,
1 - 155
2 -160
3 - 140
4 - 155
5 - 140
6 - 160
7 - 160
8 - 145
Thx Team!
If the engine has been sitting a while , sometimes all it will take a just a ver small piece of carbon ro get between the valve and the valve seat and give a lower reading . Best to have the engine warmed up
Hey Guys,
1 - 155
2 -160
3 - 140
4 - 155
5 - 140
6 - 160
7 - 160
8 - 145
Thx Team!
Ayuh,... It depends on what motor was in the other boat, 'n it's Vintage...
