- Jul 18, 2011
- 17,704
As you may know from some of my previous posts, I am doing a top end rebuild of my 1991 Mercruiser 7.4L. That year is kind of on the border line between the "Gen IV" and the "Gen V" 454 versions. As best I can tell, the engine is a "Gen IV". It has an engine code on the block of T04060XW which matches to a "Gen IV". What is throwing me off is that the head gaskets that I pulled off the engine look more like the "Gen V" than they do the "Gen IV". (i.e they have 1 less cut out for the water passage on both ends of the cylinder row.)
I am wondering if this engine might have had a valve job done by the previous owner and they put "Gen V" version of head gasket on instead of the "Gen IV"?
Engine serial number is: OD446420 Engine block code is: T04060XW
TIA for any insight.
