1981 merc 18 manual start mod to charge Elect trolling motor Battery
Merc 18
Hello,
Is it possible to to modify a pull start 1981 merc 18 to produce dc current to charge 12 volt deep cycle batt used for eletric trolling motor?
water world
Re: 1981 merc 18 manual start mod to charge Elect trolling motor Battery
find s
oldman570
Welcome Merc 18 to the fourm. You sure can put a charging system on your motor. You will need the charging coil, rectifier, battrey cables, 10 Amp fuse link, wire, and time to do it. You should be able to pick all the parts or a charging kit thru most suppliers, or boat shops that might have a older Merc laying around. Make sure you have the SR# and do a search for outboard parts supplyers. There are several that should be able to help you out. Best thing is to call there PH# and talk to a teck, as they will know evrything you will need.I have done several mods to mercs, and one other item I would get would be a service manual for the motor, if you plan on keeping it. Most manuals will have a wiring digram for the motor and is mighty handy down the road also.
Best boating and BE SAFE,
oldman570
Faztbullet
Yep, just install a stator(part #86704A10) and a rectifier(part#816770T) a fuse/circuit breaker and some 10 guage wire. The only bad thing is this is a 6 amp system and thats running the motor at WOT, at idle it wont charge but 1 or 2 amps back into battery so you may not see much benefit unless you have some long, long WOT runs to your next fishing hole.
