Re: float height
i think monte has it backwards. the float should be parallel to the carb body when the carb is held in its normal mounted level position. turning the carb upside down simulates the carb shutoff position when the fuel bowl is full of fuel. I don't know that specific motor but the 40-55 hp models run 1-1/8 to 1 5/8 in , with 1 1/2 inches considered about right when measured from carb body to lowest level of float when holding your gauge or rule square and 90 degrees to the carb body
