Dear All,
The problem: A small amount of water is making its way into the oil of my in-line 6 165 HP mercrusier from 1975. The quantity of water is very small (after sitting for a week, the water in the oil settles to just barely touching the dip stick end). The water doesn't seem to boil completely off even after running the engine for an hour or so but it does get whipped into a small amount of froth that can be seen on the top of the dipstick (though the oil remains clear and clean.)
Here is my blindlly ignorant diagnosis: It seems like there is a slow leak in the block somewhere. It's not the head gasket since the engine starts up without any problem and runs fine (indicating good compression) so it has (or does it?) to be a crack in the block.
Prognosis: not worth repairing?
Sincere hope: I am missing something obvious that would suggest something other than a cracked block to explain water in the oil.
Any ideas would be very welcome!
