Removing oil filter
MJJ
I have a 2008 Bayliner. 185 195 HP 4.3 L. Is the an easy way to get to the oil filter to remove it or a type of wrench I can get to reach the filter?
Re: Removing oil filter
Ayuh,.... Usually ya need to remove enough of the Boat to get down there...
I use a snap-on belt type filter wrench for oil filters on most everything I change oil on....
I also use Baggies freezer bags, in boats anyways....
Crack the filter loose, 'n pull the wrench out, then slip a baggie up around it, 'n spin it off...
It drops into the baggie, 'n ya save cleanin' up the spillage...
Remember, yer lookin' at it upside-down, so turn it backwards to loosen it....
Brentathon
I like the metallic cup type of oil filter removal tool the best. Can use a 3/8" ratchet; and they grip the filter at the end (where it's stronger) and where they usually have flats (or dimples). Tools that grip (or squeeze) in the middle of the filter can start to crush it, and then you can really have a nasty little problem.
Just don't overtighten with the cup-type tool, it's easy to do since you have a good lever arm with the wrench handle.
crazy charlie
[QUOT
Just don't overtighten with the cup-type tool, it's easy to do since you have a good lever arm with the wrench handle.[/QUOTE] Hand tighten the best you can after completely lubing the entire top of the filter including the rubber and the threads with either fresh oil or grease.Hand tighten only.....Unless you are a sissy boy,then give a quarter to a half turn with a filter wrench AFTER hand tightening the best you can.Charlie
crazy charlie
BTW,the first line was a quote,dont know why it blended into my reply.Charlie
cr2k
I like oil filter pliers, work much better than band wrenchs if filter is over tight.
MJJ
I like this one with ratchet. I will try it. The problem is I can't reach the filter with my hand. The ratchet will extend my arm.
Thanks
90stingray
The oil filter pliers from harbor freight are like $5 and work great. I end up using them to remove old sprinklers in my yard too... best $5 spent.
