Re: Prop hub question?
The last prop I bought was a Turning Point Hustler for my 90 hp engine. It is my first prop with the Flo Torque (I guess) hub. The hub is plastic and is molded around a brass hub that has several radial spires coming from the hub that the plastic is molded around.
If you hit something, I don't see how the hub can take the blow, nor do I see the ability of the hub to soften the impact of gear shifting.
Rubber on the other hand gives when you shift gears and slips when you need it to slip and recover afterwards....to keep you off the rocks.
It's kind of like having a shear pin of yesteryear. Once you whack it you just lost your props ability to move water. Just my 2 cents but I bet I'm right.
Soooooooooo what's behind the industry's big push for plastic hubs? I don't think I like them and don't plan on buying another prop with one.....if I can find it.
Now what this has uniquely to do with toons beats me so sorry but I can't help you there.
My 2c,
Mark
