Johnson seahorse 5.5 water pump
Aroundthebend
Having a problem removing the foot. The shift rod linkage will not disengage. Can anyone help me with this procedure? Found the old motor in a barn, got it running, just not cooling. Don't have the money for the Manuel. Thanks for any heip.
petryshyn
Re: Johnson seahorse 5.5 water pump
Can't be sure without serial number, but its likely the powerhead has to come off to disconnect the lever.....:(
Aroundthebend
I was afraid of that. Model CD-16 Ser 1909931
Is there anyway I can remove the shift rod? Maybe by removing the skeg?
Aroundthebend
Thanks for the information. I guess I'm off to pull the powerhead. Wish me luck
