Help TT swap.
shadowslayer62
hello everyone, I have a question. would a 1985 mercury black max 150 hp TT fit on my 1989 115 hp mercury?
Faztbullet
Re: Help TT swap.
If its the 3 ram unit ...yes. You just have to make sure if the motors are the same as they had a 2 and a 3 wire t/t motor.
shadowslayer62
Re: Help TT swap.
mine is a 2 wire the black max is a three wire. Will it still work? and yes they are both 3 ram
Faztbullet
Re: Help TT swap.
Yes it will work but you will need to do a little rewiring on relays to make the 3 wire work....
