Hello all. I have a 115393M. Those of you who know that number know its a 115hp 1973 Evinrude. Coming into summer we are once again heading for the water. I made a mod 2 years ago, comprising of a 4psi electric fuel pump and 3.5psi cut off switch for fuel supply. This system works great and we have put 150 odd hours of water sports and stop start caper on the motor trouble free. My main reason for doing this mod was because I use Four tanks and got sick of priming.
Now on the sad note. Im not familier with the tuning process of these perticular motors. Can someone inform me of spark plug gap? Also I am currently running 40/1 mix. Is this high do you think? And the carbs. What is the correct float level and where is it measured from?? Had the jets out and cleaned. Any other things to do to the carbs? I have some trouble cold starting. Its like its getting way to much fuel.
Thanks. Trev.
Thanks. Trev.
