Seized shaft removal 1980-7.5 hp Johnson
dave pollock
While servicing my lower leg and winterizing I have found the propshaft to be seized in the head and one of my coil packs has wept . The motor runs well and shifts great . I am wondering -do I try a slide hammer-or is there a better way? Also how to decipher the coil issue J8RCSS motor. Thx.
boobie
Re: Seized shaft removal 1980-7.5 hp Johnson
Are you talking about propshaft or drive shaft???
dave pollock
thx driveshaft...
wondering about heat -a press or -slidehammer
boobie
Is it only the d/s stuck in the p/h or is the whole l/u still on it??
James R
If the shaft has pulled out of the lower unit, which they very often do when you heave on the lower to free it, sit the motor on the fly wheel with shaft pointing up and run some PB Blaster down the shaft. Try jiggling the shaft to get the Blaster into the splines. Leave it overnight. Jiggle it some more and give it more PB. Leave it some more then carefully clamp a good vice grip on an unimportant part of the shaft so as to tap the vice grip and shaft away from the PH. Be patient and try not to damage anything.
Once out clean the splines and use a waterproof grease on the splines.
boobie
If this is the case you may want to mix up some ATF and Acetone 50/50 and try that. PATIENCE !!
dave pollock
Thank you both -for your suggestions.....I will let you know in the coming days how this old girl responds to a little persuasion. The lower leg does in fact come off with the gear selection rod-that drive shaft needs some love....here goes.
Haffiman
The easiest is to remove the powerhead from leg with the shaft.
Clamp it in a vice, power head down.
Then keep pouring all the funny mixes you get adviced to pour.
After some time, carefully try to knock the PH off the shaft.
However be aware that you might end up with a spline-less crank.
If you do not want to experience the latter, this is a naughty emergency way:
Cut the shaft about 1-2" above the water pump.
Weld on a socket on upper part, grind a square on the lower that fits into the socket. (3/8).
Be sure the total length of the shafts are the same as the old 1-piece shaft.
The above without warranty, but have rescued 'me' quite some times. Cheaper than replacing the crank.
boobie
I've got an old saying that I learned yrs ago. " Do it right, or don't do it at all". And then there are cobblers.
boobie
TN-25, that's a great idea. Learn something new every day.
F_R
So happens that just this morning I removed a stuck drive shaft (powerhead off). I did it by fabricating a clamp collar for the shaft and beating it out with a slide hammer after a long soak in Kroil.
However---no surprise, the splines in the crank are almost gone. RUST is why, and why it was stuck in the first place. Well actually the original cause was lack of grease and a missing o-ring. For lack of a 10c o-ring, a motor is lost.
