Re: warning horn sounds at start up
Test the harness by disconnecting temp switch, oil-tank sender, and electric VRO plug connection.
If horn still goes on constant when ign ON and engine not running, split the control, remove the brown signal wire to the horn and test again. If horn still goes on, change horn.
