I have rebuilt carb and fuel pump. Carb adjusted at 2 turns out. replaced pulgs, points gaped at .20, and replaced 1 coil its getting good fire. The problem is it won't open up it just boggs down. doesn't matter how you set the carb. Also getting fuel out of the two small drain holes just above the foot. Also replaced gaskets in foot and impeller. acts like it has a miss. The cam is new as well. The old one was broke just befor the lobe. Can anyone help me I have done everything I know. Please help.
