Re: 5.7 4bbl to MPi or TBi, a project for the winter.
Thanks for all the positive and helpful responses folks, I think the safest way is to go the all new parts route... it's just trying to find a kit that is available off the shelf... the holley TBi kits seem a bit too simple... from a bit more research I think I will go MPi or TPi for the best results. I am considering this -
http://www.affordable-fuel-injection.com/ixxocart/products/Chevrolet_Marine_MPFI_System-25-41.html
kind of funny how tossed together that kit looks for the price. looks like they just grabbed a thunderbolt distributor, a holley fuelie manifold and a 727/730 series ecu and tossed in some "you cut to length" pigtails and a map sensor.
it really does look like the 727/730(NA engines)/749(turbo) series ecu. GM used it in ALL kinds of engines in the early 90's. if its not actually one of those ecu's then they are at least using the case from one and maybe filled it with megasquirt components. they all have the same primary part number (8 digits ending in 727/730 or 749) and then a secondary number that breaks to the engine size/chip tune. lots of info out there on those. I havent had personal experience with it yet but the thunderbolt distributor is the marine GM distributor that works with an EFI setup. there are diagrams on here regarding it.
If you want to try a cheap OEM used setup to cobble together would be to either rob a TBI setup off an early 90's truck (ecu will be inside the cab behind the glove box door, just pop out the glovebox and there it is on the right jammed in there). Or if you want multiport, grab a tuned port setup from a camaro or corvette. they are dated now and getting super cheap on ebay complete but still very nice. only concerns would possibly be regarding using automotive efi setups in marine applications is making sure you have a marine distributor (kinda weird though since efi virtually eliminates the fume buildup carbs deal with) and proper sealing of the ecu against moisture. and yes, the 727/730 series is based on MAP sensor readings so no mass air sensor to deal with.
http://www.edgesz28.com/edgesz28/suburban/tuning/suburban-tuning.htm#diyintro
in the end though, might not matter if you cant get it working with the thunderbolt distributor...unless its ok to run the auto distributor with the efi setup.
Don't know why this comment is even relevant... a bit of a pointless brain fart if you ask me....
I live in Scotland, there are very few cars here with these engines... Most of our work is VAG group, BMW, Mercedes etc
didnt mean to sound bad just I find it hard to believe though that there arent plenty of car nuts in scotland who have started running megasquirt in their cars though...and you being in the industry I just assumed you'd hear through the grapevine about it is all.
http://www.megasquirt.info/
very cheap, very very versatile systems. and now you really dont even need to tune them anymore. they VE analyzer software pretty much tunes the engine for you.
http://www.efianalytics.com/TunerStudio/#veAnalyze
