dialed_in09
- Sep 22, 2010
- 3
Hello,
I am having a steering problem and I would like some trouble shooting to find out what I need to do and if it is possible for myself to fix it or if I will have to take it to a mechanic.
Here is the problem. I have had the boat in storage for about 2 weeks and the steering was sticky when I put it in storage to begin with but when I pulled the boat out of storage and tried to turn the motor but it was seized. So I used a rubber mallet and tapped the steering arm and the motor started moving again. So I thought it needed to be greased so I greased it and it worked that day but the next time I took the boat out the steering was seized again. I traced the steering cable and there was a split in the housing for the cable. So I had my buddy turn the wheel and rust came out of the housing could this be my problem? Is the cable sticking in the housing making it impossible to turn?
