Well, after replacing the oil bulb, oil filter, oil pressure switch, trimmed oil line connections, replace fuel bulb. I'm still getting a 'no oil' light. Finally, got the software and cable hooked up and popped the code, 35, No Oil Pressure. In the EMM memory saying it's gone off like 50+ times, which is about right.
Ran out today for about 45 minutes straight, high speed, no wake zones, etc. No issue. stopped, idled around for a while and then left, bam, no oil light and alarm. When I hit the oil bulb the alarm goes away and light stays on. The engine is getting oil as I've used about 1/2 tank of oil in the last 2 months, just filled it back up today.
Got back to the slip and ran for 30 minutes on idle with no alarm/light. Turned off, ran for another 10, no issue. Went inside to watch a football game for 3 hours, came back out to move back to another slip and in reverse, right out the slip, at idle, 'no oil light' / alarm goes off before I can put it in 'forward'.
Turned off, pumped the bulb, idled for about 5 minutes over to my slip without issue.
And advice on where to go from here?
Thx
Thx
