So I recently bought a boat that has a fleetwin 7.5 on it. I was out running it today and everything was going fine until it seemed to start slipping out of gear and winding up really high but not going anywhere. . . It only happened one time, limped back to the dock and went out closer and ran it hard to see if I could make it happen again to diagnose but it wouldn't. It was at full throttle when it happened and would start pushing again when backed off. Did this about 3 times but I backed off and got close to the truck in case it totally went out.
Is there some sort of gear or something in the lower unit that is causing this? It might also be that I'm an idiot and didn't have it fully engaged in FORWARD. . . but it seems that I have seen outboards do this before (mostly from the props with rubber inside that slip when you hit something (shear pin type idea) that the rubber goes bad on).
Any help would be much appreciated! Kelpy
