What would cause a battery to completely cook the electrolyte out of it?
I was checking over my boat this evening and noticed the MinnKota MK330 charger indicated I had a battery connection problem. Wierd??? That battery was fine and full of electrolyte, holding a charge and providing power OK this spring. Upon further inspection I found all the cells were dry. I swapped the dead battery and checked all the other batteries. They were OK, only a touch down on electrolyte. I plugged the charger back in and all the batteries showed full charge in 15-20 minutes.
I only charge this battery off a 10 amp/bank charger, so it wasn't being hit with a lot of current during charging. I did leave the automatic charger connected to the batteries for a couple days this summer, thinking it would shut down when the batteries were completely charged. Maybe the battery had a marginal cell and leaving the charger connected for several days overcharged it, boiling the electrolyte out? The battery is from 4-07 and has been maintained with distilled water and charging after every trip, or charged every month or 2.
I've had batteries drop a cell before, but not go completely dry. I filled it and it took something like 3/4 of a gallon Voltage was at 4.5V :facepalm:
