bayscallop
- Oct 20, 2011
- 2
Hi, hopefully someone out there can help. I have a 1996 25HP Yamaha pull start engine. The engine starts great, idles nice, and runs very strong. I just did a compression check on it today for the heck of it and it tested at 60 psi in both cylinders. I removed both plugs and pull the cord two or three times for each check. I even borrowed a different pressure gauge from my neighbor and it came up the same. Am I doing something wrong or can an engine run great w/ 60 psi per cylinder. I was always under the impression it should be about 115 -120. Any ideas?????
