My boat is a stern drive and I live in middle Tennessee. During the winter we often have plenty of days in the mid 40's but dropping down to below freezing at night. I am planning on continuing to use my boat thruout the winter and see if I can't chase down some smallmouth and striper.
Of course the biggest thing is keeping water from freezing in my engine and outdrive.
It's actually pretty easy to winterize - there are 2 screw in plugs per side of the engine, one on the block and one in the exhaust manifold and you just unscrew those to let the water out of the engine.
On the outdrive, an OMC (1988), I will have to do some research, but I think you pretty much just lower it all of the way and let the water drain out on it's own.
I am a poor fisherman and can't really afford to have a cracked block or manifold nor crack my lower unit.
So I have been thinking what I need to do after every trip to insure I get all of the water out if it may drop down to freezing that night.
On the engine - I was thinking maybe after I remove the 4 drain plugs, blowing compressed air through each drain hole ? Not sure tho if I wouldn't just be blowing the water back into the engine ?
On the outdrive - is there a way i can blow compressed air through it to insure all of the water is out ?
Unfortunately, right now it will not be stored under a roof, just under a cover.
I was contemplating getting 1" foam insulation and making a "box" that I could enclose the outdrive in and have a light bulb inside in case all of the water did not drain out, hopefully keeping it from freezing ?
For the engine, it is already enclosed of course so I could just maybe stick a light bulb or 2 in the engine compartment.
Any thoughts or ideas on what i need to do ? Will be my 1st winter with the boat and I would sure hate to mess it up by forgetting something
Thanks for any info.
