1974 Mercury 500 Thunderbolt manual tilt not working
rjam4
'74 thunderbolt 500 manual tilt will not work.
Can anyone post a repair or owner's manual?
Tried in forward gear, unfreezing the main hinge tube, pressed "dog ear" looking things,
need to take it step by step to determine the issue.
Thanks.
FLATHEAD MAC
Re: 1974 Mercury 500 Thunderbolt manual tilt not working
CAN YOU post pictures ?? i have same motor unlocs in forward , tilt motor up and flip lock to hold it up facepalm: what way is it not working??
rjam4
Same motor, it wont lift up..for trailering/launching, had it in fwd, still stuck. I know its something simple, what is the exact tilt process? Ty!
GA_Boater
Fwd, lift. Are you sure the motor is shifting?
rjam4
Yes, forward, lift=hernia and back end of boat lifting, does the long pin have to be in one of the holes for it to release? Because ive taken that out..sorry to sound rediculous, I am handy, refurbished my whaler, and basically rebuilt this motor, im just stuck here and dont want to break anything
GA_Boater
That long pin - is it L-shaped with the movable flag? If so, that's the tilt pin. The reverse lock latches on the tilt pin in reverse. If you have the tilt pin pulled out and you can't tilt the motor up something is messed up in the clamp & swivel. Or the tilt tube/swivel bracket is frozen.
rjam4
Thanks! Ill let you know.
