Hello,
I had a mishap today with my boat and I am wondering if I damaged anything. Here is what happened.
Pull my boat (2002 Sea Ray 185 4.3 L I/O) out of the lake, winterized it, push it back into my garage. I made a mistake before disconnecting the trailer tong from the SUV, lowered the stern drive (as recommended by the manufacturer) for winter storage. Then I proceeded to raise the trailer tong and as a result pressed the lower unit on the garage floor. After I disengaged the ball and moved the SUV, I realized what I had done. I immediately lowered the trailer tong, removing the pressure from the drive.
To make sure the power trim works, I did raise the lower the lower unit up and down a couple of times and things seem to be working OK. I did not see anything bent or cracked from the outside.
Could this accident have caused some damage to the alpha one lower/out drive unit that I could not see? I do not want to put the boat back in the water to test everything out now. I have to wait until next spring and I am worried.
Any thought? I appreciate that.
Sam
Sam
