my 1976 70 horse johnson
madmar
i 'm wondering if any one can help me,i have 1976 70 johnson,i just changed the head gasket because i had water coming out of number two cylinder the middle one.i put the ears back on and tried firing it and water was coming out of the middle cylinder again ,is there another gasket i need to change or what ,please help,my name is bradif any one can enlighten my problem would be much appreciated.Thank you you.....
dcreek
Re: my 1976 70 horse johnson
Wow, could be several things, cracked cylinder wall, wrapped head, corrosion of the aluminum around the steel cylinder sleeve, not allowing the head gasket to seal. Did you torque the head bolts? After running did you retorque them again? Any broken head bolts? Did the engine ever overhead? That could cause untold number of problems as well as the ones I mentioned.
