knock sensors used for draining block on 7.4 GiPEFS ???
bear_69cuda
Good day gang,
In the service manual it says to remove the port and starboard side knock sensor's to drain block, but on my block I had two brass 9/16" plugs about an inch lower and aft of each sensor. When I removed the plugs a ton of water drained from the block. Is it still necessary to remove the knock sensors? The knock sensors show no sign of being removed ever...
2000 7.4 GiPEFS SN:4012007343
Thanks in advance!
Don S
Re: knock sensors used for draining block on 7.4 GiPEFS ???
Since I can't look at it, I will just take a guess and say it's probably ok. There may have been changes in the block after the manual was printed.
