saab84
- Sep 25, 2011
- 4
(boat is new to me) took the boat out the first time it did not run well at high speed. I just rebuilt the carbs new fuel lines carbs looked good put it all back together went down to the boat ramp (its right around the corner) put engine in the water about 5in above the top fin was adjusting the carbs when the warning buzzer came on the right side was hotter than the left side.
Checked compression before taking to boat ramp all 4 where at 125psi
Water pump? or too rich/lean when adjusting the carbs?
Thanks
Thanks
