good morning everyone. I have a 97 rinker 182 with 4.3 merc alpha 1. I have only had it now for about two months. It has a new motor with about 12 hours on it. everything works and runs well. I am only having two small snags to dig into that i am looking for some trouble shooting tips on.
1. My temp gauge dosnt work. it dosnt do anything. just sits all the way to the left. Is there a way to test to see if its the guage or the sensors?
2. Tach works, but after running abit or stopping and restarting it shows a higher rpm then the engine is actualy doing. sometimes it gets stuck at 3000 while idling shows maxed out when you give it some gas and may return to normal in a minute or two. i am guessing bad tach but i would like to trouble shoot to make sure first.
3. if i have to replace these gauges where can i find them?
thanks robert.
p.s. dont go full roller rockers. push rod went through the rocker. converted back to stock rockers at dealer for $.
thanks robert.
