Time to winterize; I store my 8HP Honda in my basement on a stand. I like to run it for a few mins in a garbage can of clean water, then drain, change oil, gear oil. I also like to run it dry by unhooking the fuel line. If I spray fogging oil in the carb throat, it dies, thus I can't run dry. If I run dry, it's not sucking fogging oil in.
Is it better to 1) run it dry, then do something like spray fogging oil directly into the cylinders, or 2) maybe to spray into the carb and then use the carb drain plug to empty the fuel? I'd also remove and blow out the pilot jet, because it is easily accessible on this carb.
Thanks, Peter
Thanks, Peter
