JSGOLD
- Sep 22, 2009
- 609
Last trip out I noticed what appeared to be an abnormal amount of either smoke or steam coming out of the motor heading back to the dock. Pee stream solid, but I checked when we got home and there is steam coming out the exhaust still yet. Was hoping it was simply the weather...Anyway pee stream is good, ran the motor for 5-6 minutes ans water in pee stream was warm but not hot. Not sure if this is normal as I am only idling it with a little speeding up here and there. Head hot to the touch in places, but can hold onto it for a second or two. Not sure....does this sound normal or possible thermostat issue or something worse? My 55hp shoots water out the exhaust but never noticed this motor doing that or sending out steam....Motor is a low hours 1984 Evinrude 8hp long shaft, E8RLCRM, used as a kicker motor. I notice no steam or leaks anywhere else on the motor.....
