NS15B2 Looking for Carburetor Kit or parts to rebuild
japrater
Hello,
I've been looking for a carb kit for a NS15B2 or at the least the gaskets for it. Can anyone help?
flangler
Re: NS15B2 Looking for Carburetor Kit or parts to rebuild
I had the same problem with my M9.9B2. I just searched and searched and searched. Look at Nissan dealers in your area and call everyone. They should still make some gaskets for it. Probably not kits though being it's an older motor. I was able to get the float bowl gasket, and the gasket that goes between the carburetor and powerhead. Good luck!
Sea Rider
Could you place pics of the old float, valve, carb gaskets, gas pump diaphragms, don't know this old model, would actual 15D2 parts match ?
Happy Boating
pvanv
The B2 carb is quite different from the D2 carb. Different casting, different bowl, different float, etc. The only real "gasket" for the B2 is the bowl gasket. The early B2's had a cylindrical bowl with free-floating "donut-shaped" float, and almost nothing is available for those carbs. The later models (depends on serial number), had an "octagon" bowl, and hinged float. The gasket for that carb is: 350031210M, GASKET, FLOAT CHAMBER, $4.85, and is still available. OTOH, if you need bits for the integrated fuel pump, some are still available.
flangler
Oh and if you need a needle valve they don't make them anymore. However, I was able to match one up from a Honda lawnmower carb, and it operates just fine. Mine had the rubber seal on the needle valve not the seat. Just a thought if your looking for one.
Sea Rider
Japrater, if you plan to stick with that oldie, you better buy important parts while still available, or you could end with a grounded boat, and that would be a real pity.
Happy Boating
flangler
I agree with Sea Rider. I ordered a extra pump body and gaskets when I found them. They are inexpensive and always good to have spare parts. I can't wait til I can afford to buy a newer motor with parts on hand!
flangler
Oh and pvanv, I must have a later model because I have a octagon float that is hinged. That good info to know. Thanks.
japrater
Thanks for all of the info everybody! My uncle is doing the work on the motor for me. I left a message for him to get me the serial number, will post when I hear back. Thanks again everybody for the useful info!
