idonthaveaname
Banned
- Sep 23, 2010
- 1,058
My 1984 Johnson appears to be leaking oil from the gearcase. I noticed some black oil sliding down on the back of the prop from the lower unit after running it with muffins at the house. Next day I noticed about 2 ounces of tan oily yuck under the prop on the driveway. I tried to drain the remaining oil to check the lower unit and about 6 ounces of water (clear) came out...no oil. I pushed in about 20 ounces of oil and it needs more. My guess is it was empty and I am lucky it didn't blow out. After replacing the oil, nothing else has leaked, but I haven't run it either. Anyhow, I'm thinking the seal at the prop is bad...could be more (what do you think). How difficult is it to replace that seal? Special tools or car mechanic stuff?
