Re: Merc 400 45hp questions
Hi Max,
The Merc 400 would be a 1960 or 1961 model year (depending on serial number). Although it could probably run quite well at 50:1, and many folks do run their old Mercs on that mix, the recommended mix is 24:1. Personally, I run mine somewhere in the middle at about 32:1. Mercs of that era are pretty advanced as far as bearings and scavenging goes and they handle the leaner mixes quite well. BUT, go leaner at your own risk...
As for the propeller, it is entirely dependent upon what you are going to do with the motor. And blade count isn't nearly as important as pitch. Light runabouts respond well to 2-blade, high pitch props. Heavy cruisers and pontoons need more blades and lower pitch. You want your RPM to be able to hit the sweet spot in the 5000-5500 range, regardless of what the application is.
