Bought this boat recently knowing it needed some work. The transom had bowed from true (3-4mm) enough to split the fibreglass cap and show movement at the back corners of the splashwell when lifting the bow from the trailer using the outboard. The lips of the hull and top cap had split on the left hand side and the top centre cap had an aluminium strip with 6 screws dropped vertically and lots of silicone.
The father in law was keen, so we cut the rear of the splashwell out with a view to chasing the rot. Unfortunately, aside from the rot around one of the lower bolt holes and some delamination in the top left cap, there is a quite solid, (although bowed) slab of timber under the glass. I am not looking forward to trying to separate the timber from the gelcap at the rear.
Not expecting more than a year or two from the boat and it is currently carrying a 45hp Chrysler. Is it worth either
A) removing the top half of the transom trying to maintain the gelcap,
B) cutting the back gel cap out with a tab and replacing the entire transom,
C) glassing it all back up and getting a summer out of it? If glassing back up I would probably put some penetrating resin on the delaminating section and clamp it up first. Stringers are solid and drain plug doesn't have any rot or softness. If I were to glass it back up, would a plate or brace across the top be recommended?
Thanks for your help.
