I have a 1989 Basstracker Pro 17. I get water in the bilge and have to use it about 4 times when out on a 7 hr fishing trip. I cannot find the leak. I have filled it with water and marked and fixed leaks. After fixing about 4 leaking rivets and one hairline crack, when I fill it with water I cannot find anymore leaks. But when out on the water I still get water in bilge????? It also seems as if I take on more water when I have driven fast rather than just sitting, trolling, fishing. So I am assuming I am getting a leak under pressure. Problem is how do you find these? I am going to take out the flooring this winter, but how would one test rivets etc that only leak under presssure??? Or do i just plan on fixing them all, gluvit???
