Here's a rundown of what I'm experiencing...
I recently rebuilt the fuel pump and replaced any sketchy lines going to the pump. I also changed the plugs about 2 months ago.
Cold start:
I thought that this would have resolved my issue...but, it still takes a fair amount of cranking to get the engine to fire, and when it does, I have to crank it over a few more times to get it running. After i feed it some throttle it is good. Runs strong at all RPM levels, and will sit and pur at idle. Can not say when the last time the fuel line form the tank to the bulb and bulb to the fuel pump was changed, but i do know that it does not remain firm (from reading the other posts, i should probably change that).
Warm start:
After setting for a while, It will fire a couple of times before running. Often times it will smoke for a bit before calming down and idling.
Thanks in advance.
"91 Black Max 150hp v6
Cold start:
Warm start:
Thanks in advance.
