So I finally got the opportunity to take the boat out for a bit on the lake. I recently have drained all of the old nasty fuel out of my boat, cleaned the carb, fresh good gas in and now it will run like a champ. Boat starts right away, idles real nice and revs great. Now I am tryin to figure out why it is tryin to over heat. I ran the motor in the lake, and it heated all the way up to 180, I shut it off and checked out the raw water pump, the impeller is fine, flexible and no broken vanes. I put the cover back on, primed with dish soap and ran again, same thing. My question is, since I know the raw water pump impeller is good, does the pump body need to be replaced or should I just replace the circulation pump on the engine first? I am not sure which is causing my issue and I hope with the help of the people here I can get a good run on the boat before I have to put it up next weekend. I am prepared to replace both pumps, just seems excessively expensive, and not really troubleshooting at that point. Would rather just replace the part that is broken, just don't know what part that is. I suspect that the Raw Water Pump body is damaged and not functioning properly, want a second opinion. I have checked all the supply system for obstruction, and have had no problems, I back flushed the drive from the hose into the raw water pump and back. No leaks, I even hooked up my shop vacuum and used soapy water at each junction looking for bubbles. Only thing left is a bad pump, one or the other.
