Chet labrozzi
- Jul 31, 2011
- 60
Ok, here is a question for you...Why doesn't the pink RV antifreeze that I used to winterize my boat now work with my antifreeze tester? I bought a new boat this year and I'm new to this forum so I have been doing alot of reading an research here. After reading some post about using muff's and Rv antifreeze I decided to go pull off the lines on the block and look, the lines where full so I tried to test it, however it doesn't read on my antifreeze tester? is this normal? I dumped the remaining antifreeze down the hoses and hopefully it's winterized!
