Conversion from tiller to steering 2001 30 hp
Looking for advice or direction here.
I am sure there is something available, just dont know where to find it. I am in the process of hooking steering, electric start, and controls up to a 2001 Johnson 30hp 2 stroke tiller control outboard. Its obvious I need to remove the tiller arm to connect the steering drag link, but what I dont know is what kind of parts I will need to purchase to hook up the controls. Its a single lever control box with two cables.
Is there an adapter kit available? If so where can I find one?
Thanks all!
Pat
clanton
Re: Conversion from tiller to steering 2001 30 hp
BRP parts site accessory parts manual.
tphoyt
I just did my 2000 40hp and I found that the cables will hook up at the same location as theyt are now. I removed the tiller handel and cables as well as the wiring and spliced the wire to a kill switch on the console. you will then need a steering link kit avaible at many places as well as here on this site.
Good luck
