smallies4evr
Thread starter- Joined
- Feb 17, 2011
- 8
Went fishing yesterday. Lifted the motor to remove transom saver, launched boat, lowered motor and got underway. Motor would not continue down to the position to trim the boat to plane. Motor will not lift or lower now. Checked all connections, cleaned with wire brush, reconnect all wiring. I checked the solenoid with multimeter and I have voltage everywhere I should according to my manual. I have 12 volts at the wires going to the tilt/trim motor, however motor doesn't run. My engine is in a 3/4 down lowered position. What do I need to do to get it up to test the tilt/trim motor? I see in my manual that there is a check valve, etc but I can't get to them with my engine in its current position.
