The early 70's Lazy Days in the slip next to me is equipped with 2 215hp Mercruisers [ Ford 302s I guess. Don't look wide enought to be 351's ]. He has been having trouble with the motors stalling and I volunteered to adj the float levels and the idle mixture screws. He went out to the pumpout and when he got back I went to adj the carbs while the motor was warm. <br /><br />The float levels were a little off but not really enough to significantly affect the running. The weird thing is that the idle mixture screws have NO effect on the running of the motors. You can screw them all the way in and there is no difference in the idle. Turn them 3 turns out and you get the same result. I set them at 1.5 turns and left it.<br /><br />What's up with these carbs? I have never seen a Holley equipped motor that wouldn't stall when you got the idle mixture screws way too far in or out.<br /><br />The other weird thing is that the bowl vents are straight, not bent over the carb throats ! The carbs are black and appear original.
