Bayliner 185 Gear Oil reservoir
oscarlee
got a 96 Bayliner 185, Gear oil tank is leaking where can i find replacement. It is a plastic tank mounted top right side engine.
Philster
Re: Bayliner 185 Gear Oil resevior
What engine and drive do you have? Merc?
roscoe
Gear oil tank?
Hydraulic tilt n trim reservoir ?
Oil injection tank?
Outboard or i/o ?
brand?
outdrive?
John_S
Assuming this is a Mercruiser and talking about gear oil res, look to see where it is leaking from. It could be the hose connection. If bottle is overfilled, it will leak as the drive warms up. If bottle is cracked, you will need to go see a mercruiser dealer or parts supplier. You can find part number on MercruiserParts.com.
roscoe
Contact any Mercury dealer for the part.
oscarlee
Contacted Local dealer, plastic tank has a crack will replace thanks.
