Premix motor that I have recently purchased. It took me awhile to figure out the starting sequence. Once I did motor ran great. Went to the lake today. Same starting steps, purge fuel bulb til firm, spray premixed 50:1 into each carb, turn key, press key in, turn key while holding it in. Motor turns over and over but never acts like it wants to start. Try 2 more times and tilt motor up, pull off the ramp. Once I get away from the ramp and climb in the boat, premixed has poured out of somewhere(carbs?). Pull plugs, lil wet but not bad. Reinstall plugs, back down ramp, try again with exact same response. What's with the premixed running out?
