Re: Mercuiser 140hpTrailer switch
typically on our old boats w/ mc-1 drives. the trim limit switch fails. so the middle only button don't work. however if ya use the trailer function. using the top two buttons together, the drive will raise. in trailer mode the failed trim limit switch is bypassed. you can raise the drive as far as ya want. my limit switch has failed. i just use the trailer function, w/judgment. ya don't want to get the drive trimmed so far up it's outside the gimble ring supports. they support side to side motion of the drive.
ya can also jump a wire inside the boat by passing the trim limit switch if it's failed. achris has the attachment for ya, i'll let him get onto that. i seen him around lately.
to find the trim limit switch. follow the groove worn into your bell housing, dead center disappearing behind the gimble ring. if yours is like mine, the switch will be wearing on the bell housing.
edit, if the trim limit switch has failed. best i know, it's a nla part, hence the reason for doing it like i do (using trailer function for trim) or using achris' bypass.
