1984 70hp 2-stroke evinrude
1990 90hp 2-stroke mercury
got an evinrude engine from my grandpa for free. turns out it had a hole in the block, got it half torn down to realize the salt water corrosion has bolt heads popping off left/right. about to abandon it and part it, but the lower unit has a stainless prop on it. my mercury still has the original 19p aluminum prop and its a bit torn up lol.
if the splines are the same the stainless should bolt up and work right? only other problem I see is that this is apparently a vintage stainless prop as it has NO markings on it anywhere that I can see so no clue who makes it or what pitch, etc it is. and no, I havent taken it off the lower unit yet.
